Tom - Interesting comments. I was also told by a very experienced driver who I respect, that the Gen 2 handles better then the Gen 3 on the track due to the suspension and some other features. Speed for me is not the goal but to increase my driving ability.
I'm 5'8" and do not extend past the sport bar; however, I have been thinking about getting a roll bar if I decide on the RT/10. If I decide on the RT/10, should I consider converting the brakes over to Brembo? I see that they sell a kit for the conversion.
Well, I couldn't help but modify my Gen 1, so at least in AX events, I can and have outperformed Gen 2 and Gen 3 cars. It goes back to expenses- if you want to change springs, shocks, etc, is it cheaper on a Gen 2 or 3? Dunno, but guessing Gen 2.
The broomstick rule, I find, varies greatly by series and tracks. Lime Rock has the stick rule, but it also depends on whether the event is a controlled speed driving school or a "red group can run without instructor" driving school. At Lime Rock, it depends also if it is the Corvair Club event (don't care as long as you don't punt a Corvair from behind) or the Porsche club (vee vill make sure you get clobbered by dee rulze!) As you can tell, I have received conflicting advice, even at the same track.
With a roll bar, I think your safety issues are solved but you still might need arm restraints (in case of roll-over).
Aaaack! Brakes! Yes, Gen 1 and 2 brakes are poor because the rear calipers are too small! Upgrading the fronts is the wrong direction. In fact, if you get the "upgraded" Stoptech front brake kit, you really get calipers with
smaller pistons. The biggest improvement is getting enough rear brake capability to balance with what you have in the front. Ta-da: like the 40mm rear brake calipers. Spend 20% of the "4-wheel big-brake kit" cost and get 99% of the benefit. (sorry, can't make them look as good, but braking data shows they perform!)
Read up here: (you must click every tab on the left!!)
40mmBrakes Home
and then read here:
StopTech : Balanced Brake Upgrades
Keep in mind that Stoptech's discussion assumes the OEM rear brakes are at least "big enough" while the OEM Viper rear brakes aren't. You can prove this by removing the proportioning valve in any other car and the rear wheels will lock first; try it in a Viper and the rear wheels still won't lock up. PM me with any questions about this.
