S/C heat soak
Landman
West Virginia
I have the NOVI2000 with the included liquid to air intercooler. Is it efficient? I lose a ton of power from outside temporatures. Is there anything I can do to keep it more consistent? Front mount or any other mods?? Any suggestions would be great!
Colin
Qualitywires.com
Louisville, KY
Problem with front mount air to air intercoolers are that they tend to block alot of air to the radiator which can cause your car to over heat. air to water will get heat soaked eventually so it's kind of a give and take. You could go with a larger water heat exchanger with a larger flow pump.
L
Landman
West Virginia
Does the air to liquid setup use the same coolant that runs through the engine? So if the engine runs hotter the coolant in the intercooler does also?
rlamorte
