SC RT/10 recommendation for Accusump, any EPC Switch Problems since 2007?
Stahlhart
Hi there,
I´m thinking on getting a accusump on my supercharged RT/10.
I read about some problems with the EPC Switch:
http://forums.viperclub.org/threads...danger-of-possible-failure?highlight=accusump
Are there any more problems with the EPC Switch?
I want to by the 3qt High pressure version. What is the correct EPC Valve Kit 55-60PSI, 35-40PSI or 20-25PSI ? In my opinion it´s the 20-25PSI Version while idling I have around 40PSI of oil pressure.
What is the better way, unsing a sandwich plate or using the return line of the oil cooler?
Thanks a lot
Jürgen
Jack B
NE Ohio
Use a splitter at the filter adapter. I will take a pic of my install and post on Sunday.
Stahlhart
Hey,
here are some more pictures of my engine built.
We made this tume with 2 Walbros 255er Pumps and we noticed that they are too small. Now I run the aeromotive stealth 340 Pumps, and we will do a new tune next year.
I also get a new paint on the viper in a few weeks...
@JackB: Which valve kit do you have?
Greetings
Jürgen
Stahlhart
Hi,
still need some informations for my gen1, can nobody help me?
Is it better to use a sandwich plate or the return line of the oil cooler ?
What´s the right EPC Switch? 20-25PSI?
Jürgen
SingleMalt
Hi,
Jürgen
You really need to talk to Todd at A&C Performance. He has done these installs (I have one -- has worked perfectly since day one).
[h=2]951.696.0500[/h]
Good luck!
rmoore8950
