,,,is it difficult to get into gear? Mine is tough, concerns??? Is it Ok to run in second to speed up the warm up process for second gear? Double clutching is also ify. When warmed up it is fine.
Aside from any mechanical problems with a given transmission, our Vipers with Castrol Syntorq as factory tranny fill are DEFINITELY harder to shift when cold...especially 1st to 2nd...than the Vipers with Dexron IIe or III or IV.
...There is a Warning sticker on the transmission "changing oil other than factory will void warrenty". keeping the RPM down, and in seconed gear sure will help warm up the trans. oil to operating viscosity, and should not harm your car, for the short duration.
