Service Engine Soon lite NOT illuminating
fildrill
NC and OH
I have a wierd situation. When I turn the key on my '97 gts to the "ignition unlock" position, the Service Engine Soon lite does not illuminate. I took the dash apart and removed the Message Center to check the bulb-its good but I replaced it anyway; reinstalled Message Center and turned key-still no illumination. Per the manual, the SES lite is associated with Pin #3 in the 8 Pin Connector plug of the Message Center. I looked at the wiring coming from behind the dash that plugs into the 8 pin Connector and it doesn't have a wire in that location. There are 7 wires going to the 8 Wire Connector. :dunno:
Does anyone know how the SES wire works?
Thanks in advance for any help.
Phil
F
fildrill
NC and OH
No codes, I've checked fuses but I'll recheck. I'm wondering if the previous owner did something so the SES lite would never come on; I think I may need to run a wire and tie it in since its wierd that no wire exists for the SES from behind the dash.
SKY1960
