Shift points
Nich0las
Has anyone experimented with their shift points at the strip. It seems as though shifting a few hundred RPM's before the redline in the middle to high gears allows for a higher trap speed, can anyone verify this?
GR8_ASP
Not for an SRT. I found near red line was best (5800-5900), but preventing from hitting the rev limiter. Using the dash shift light was reasonably close. First gear is quite difficult to shift high without an occasional rev limiter so I have started to short shift 1st (before Paxton). Post Paxton you must short shift. Too much power in 1st.
VIPER D
dutchess county, ny
not really post paxton just post runcraps. After i got rid of those pos runcrap and got dragradials its a much much better
vd..
Herc
vd.. [/quo
What tires did you do front and back? And did they change your cornering any?
Herc
VIPER D
dutchess county, ny
Drag radials (bfg) in the rear and pirelli's in the front. And yes they did change the way the car handles. Its a trade off. 1000% BETTER LAUNCH. And 20% worse handling around turns. For me the switch was a no brainer. I had no traction til mid 3rd gear b/f the switch.
vd..
ctrengine
