Short Shifter Adapter Install Writeup
CROM
Fairfax, VA
Hey guys,
I just installed a shorter shifter shaft thanks to Rich Detert's Shifter Shaft :2tu:
I also installed an 01 Shifter.
I found that none of the writeups online are geared towards the 96+ models or are very detailed. Most of the process is in the "no brainer" category, but I still was second guessing myself sometimes. If anyone wants me to do an illustrated writeup I would be happy to. I took tons of pictures and can do each and every little lame step.
Daffy Duck Viper
Austin, TX. USA.
I respectfully request that you do this write-up. One can never have too much information or details about something one has NO experience with, especially when it involves Vipers! :D Thanks.
So how long does this take? Goodness, I been waiting a couple of minutes already. Heh-heh.
Sorry, it's just that I'm an infoho. *chuckle*
C
CROM
Fairfax, VA
BEFORE:
AFTER:
THOR
TX / AZ / CA
CROM - Yes, please on the info/pics. I will be installing mine shortly. Thanx in advance. :2tu:
Jay Herbert
Sunnyvale, CA
If you'll write it up and send it to Tony, he'll get it installed in the Illustrated Instructions for all to Enjoy. I did an install on mine of a similar item from American Dream Motorsports, and have the pictures somewhere. I can find them and you can use them if you like for your write-up. Since ADM is just up the raod from me, I had them make me three different lengths, I ran the car for a while on each one untill I found the one I like the most. The shortest one was to short for my liking. I really like the solid feel W/O the rubber isolator of the stock setup.
Most of the install is similar to installing the B&M shifter that is in the illustrated instructions... 'cept instead of installing the B&M shifter, you unthread the vertical "bar" from the shifter and thread in the new unit. Most of the work is getting the interior bits and the boot out of the way.
C
CROM
Fairfax, VA
I'll write it up in the next day or so. I have tons of pictures so I should be ok Jay. I am assuming I should write it up in HTML for Tony to post?
C
CROM
Fairfax, VA
Yes, its the only way I could get the shaft off. You "may" be able to get a wrench on it, but it would be almost impossible.
I will show that in my writeup. A 19mm Crows Foot is a must.
95Viper
Phoenix
If you removed it and installed the short shifter, is there a way to have something there for heat insulation?
Mpcc
