Side sill insulation came unglued....
Ratical2
San Jose, CA
Looking for a recommendation for reattaching insulation to the side sill.
I am installing Roe High Flow Cats and when I removed the passenger side sill, I found the insulation was no longer attached. The adhesive looked like some type of epoxy. It had separated from the insulation and side sill and was rattling around inside.
Does anyone know what the correct material is? I am thinking of either a high temp epoxy or maybe a high temp RTV.
Thanks!
97snk
mine were never glued on...well the first time i took them off they were just stuck because they are wider...I pushed them out and they came right out.
slysnake
It will stay in place without adhesive when installed. Just a bear to put in place But I would guess a high temp adhesive would work
99 R/T 10
Enterprise, AL USA
Hi-temp adhesive or just lay them in place when you bolt the side sill back on. It will not move or cause any damage that I know of.
