Smog Check -- Ouch!!
Viper Byte
Fremont, CA, USA
Just had the smog check done on my Viper and it cost almost $100! :eek:
Last time I had it done (~ 2 yrs ago) it only cost ~$30. :) They now
have to place the car on a dyno and spin the back tires while measuring
emissions.
The only good news here is, thanks to Arnold, my registration fees
dropped from $900 to $300. :2tu:
VB
FrankBarba
This just started in my area of PA. You can get an exemption if you drive less than 5k per year. Cost for exemption i believe is $25, found this out after i was charged $ 75.
Tomer
Los Altos, CA
Wow, did not realise they were now using the dyno for the test...I had my last one done at the dealer, I think it was ~ $49....
If you tip the smog tech a little, can you run her up for a full power pull, and get a print out of the results???
Tomer
Bad_Byte
Corpus Christi Tx
Tomer
LMAO @ dyno run
Just had mine done and it cost $50. It had to be backed onto the thingy cause it was too low in the front.
That is the IM-240 dynamometer test, as opposed to the TSI (two speed idle) test. The CARB/EPA decided the TSI was not rigorous enough, so they made the test more difficult. However, it provides better information.
ViperJoe
Virginia
I would be saying ahhhhhhhhhhhhh after having that $600 cactus pulled out of my a$$, not ouch for that measly pin [******] $100! LOL!!!!!!!!!!!
ACELLR8
Harrisburg, PA
Frank,
Interesting I did not know you could get an exemtion. That is good news since I removed my cats as I am building the motor and added headers.
