So, you think your Viper is fast?
gofastr
N. E., Fl.
* One Top Fuel dragster outfitted with a 500 cubic-inch Hemi engine makes more horsepower (8,000 HP) than the first 4 rows at NASCAR's Daytona 500.
* Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each sparkplug, which is typically the output of an electric arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass.
*After 1/2 way thru the run, the engine is 'dieseling' from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow....
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with enough force sufficient to blow the cylinder heads off the block in pieces or split the block in half !!
* Top fuel dragsters reach over 300 MPH +... before you have completed reading this sentence.
* In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate an average of over 4 G's. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 9000 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free, & NOTHING BLOWS UP, each run will cost an estimated $1000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of the run).
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run).
6 g-forces at the starting line (nothing accelerates faster on land).
6 negative g-forces upon deployment of twin 'chutes at 300 MPH.
An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth . . . quicker than a jet fighter plane . . . quicker than the space shuttle....or snapping your fingers !!
The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta). The top speed record is 337.58 MPH as measured over the last 66' of the run (2005, Tony Schumacher).
So, in summary...Let's now put this all into perspective:
Imagine this....You are driving a new Dodge Viper SRT10 with 600 hp. Over a mile up the road, a Top Fuel dragster is staged & ready to 'launch' down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the Viper hard, on up through the gears and blast across the starting line, and pass the dragster at an honest 200 MPH.... The 'tree' goes green for both of you at that exact moment. The dragster departs & starts after you.
You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutally screaming whine that sears and pummels your eardrums & within a mere 3 seconds the dragster effortlessly catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him.
Think about it - from a standing start, the dragster had spotted you 200 MPH....and it not only caught, but nearly blasted you off the planet when he passed you within a mere 1320 foot long race !!!!
That.....is acceleration!
FE 065
MI
At 200mph the Viper'd go thru the 1/4 in 4.46 sec, I doubt the dragster would catch in 3 sec if there's only a .04 sec 1/4 mile ET difference between the two.
ViperGeorge
Greenwood Village, CO
I was following you until you said "You run the 'Vette hard, on up through the gears and blast across the starting line, and pass the dragster at an honest 200 MPH.... ". You must be quick to change from a Viper to a Vette at 200mph. :D :drive:
HSSSSSS
Red Deer, AB, Canada
I love speed. The best part about it is the G force on the launch.:2tu: I am sure I would pass out long before 8 G's, but the rush would be awsome.:D
Nice facts, but you used Viper and 'Vette in the same scenario. I will assume the Viper did not get passed?:lmao:
1BADGTS
How fast where the old rocket cars now outlawyed .I believe they were the same ET wise AS THE DRAGSTERS but with higher trap speeds (almost 400mph IN THE QUARTER)
1BADGTS
I thought so Kitty Oniel ran 3.22 at 414 mph 30 years ago.Imagine the power that car was making trapping clost to 100 mph more than ANY top fuel car.
1BADGTS
There is so much wrong on this old list.
Exactly ,not only is it not the fastest acc car on earth (well maybe NOW but not 30 something years ago )but i DOUBT a Top Fueler consumes the same fuel (amount wise) as a LOADED 747. Come on now.
jdeft1
Metropolis
My viper isn't fast anymore... but it was 15 years ago when it was built... and still running strong.
How many Gs can that dragster pull on the skid pad??
Yeah, the defense rests.
FATHERFORD
Texas
You aren't going fast enough if you can still turn.
jdeft1
Metropolis
If I can't turn... I'm going way too fast!!
To me, it's also about going around a corner.... Umm, that's what performance cars do, not dragsters... sorry for the interruption.
SkyBob
Hudson Valley, NY
Performance : what an abstract concept. It means different things to different people. It's kinda like asking what love is.
Bob
1BADGTS
Does a LOADED 747 burn more fuel than an unLOADED 747?
Bob
Dont know but i did some checking and found out a 747 produces trust which when converted to horsepower is in the 90000 range .
SKY1960
