Squeeky Brakes
Kurt 97 GTS
Dallas, TX
Squeeky brakes are just part of the Viper experience!
Luckly, you have several options that will not only reduce/eliminate the squeeking, but also greatly reduce the brake dust problem. Contact Rich Bontempi at High Performance House- http://www.highperformancehouse.com/ He carries the Porterfield brakes which seem to be very popular (there is a pad for street only use-R4S and race only use-R4). Also, I have heard very good things about EBC brakes. I'm sure others will have other suggestions as well. Good luck.
Marc Lublin
Oyster Bay, NY, USA
I was just at the plant last week picking up my new RT/10. I told the plant mgr. about my brakes on the brand new car squeaking and his response was that they make a street legal race car and that is just one of the minor drawbacks. He did however suggest the Porterfield pads, although I was told by others that they compromise the rotors a bit.
Joseph Houss
NJ USA
My 2000 had "the squeeks" for about 1000 miles...it slowly is going away...give it some time.
Brian Denham
North Little Rock, AR
My 2000 also had squeeky brakes. Got about 1600 miles on it now and it is slowly getting less noticeable. Will still upgrade to a more "dustless" pad soon.
jdeft1
Metropolis
Bahahahah!~! ..... LOL
Yep, go figure? Nine years later... they still squeel...
That's what brakes do!
eucharistos
Houston
i heard the gen 3 cars' release is iffy with the fiat thingy :rolleyes:
if only a german car co could help out :lmao:
would be nice to have spall chekc too :headbang:
:eater:
alexander m embry
I just removed and put back (same parts) driver side rear brake pads and rotor. And the squeaks went away but have started comming back slowly. My guess is that most of the squeaks come from the rear dirver side brakes that have car brake and e brake working off the same piston.
KenH
Portland, OR, USA
I use the Hawk HPS pads. They don't squeal at all and have almost no dust which is important to me since I am running polished rims. I also run a little anti-squeal lube behind the pads, but I don't know if that makes any difference or not.
Tombala
