SRT maintenance questions
knuk
My dealer told me that at 35000Km (20,000 miles) I need to have the throttle bottle cable serviced....there is no mention of it in the owners manual. I recall on my gen 1 &2 this had to be done because they were duel and out of sync.
So is this service necessary on my 03 srt?
Also, the manual calls for a transmission fluid change at the same mileage but says nothing about the filter. Do I just need to change the fluid, or the filter as well?
mike & juli
Upstate NY
Call up Chuck!!! Chuck Tator of course: 1-914-763-3136!!! He can answer all your questions! ~juli
dave6666
I think you might mean throttle BODY cable.
And I doubt your transmission has a filter.
xjrguy
Yes I would think he meant throttle body and the T-56 does not have a trans filter.
It's drain and refill.
Racer Robbie
Guilford, CT-USA
It is quite simple to see if the throttle cable is adjusted right. As long as the throttle body plate closes fully and there is a little free play in the cable you are all set. as far as your tranny having a filter, i think not. Sounds like your dealer is taking you for a ride.
