Stereo installation Questions
DrDJ
Chesapeake, Virginia
For you stereo installation gurus;
1. How does one remove the door panels on a 98 GTS?
2. What type of crossovers if any are used on the stock door speakers? If present, where are they located?
3. Most high end separates come with rather large passive crossovers. Where are people installing these?
4. How does one remove the stock head unit?
5. For those that have run all new wiring, what path did you take to get to the hatch area?
Thanks.
DrDJ
GTSnake
Motor City
Lots of screws and I think only two christmas trees. Once all screws are removed lift up and out on the door trim.
Factory tweeters have a resistor as the crossover.
Mine is installed in the door trim. It rattled at first but just stick it on with some tape or RTV.
Take off front panel, just pull carefully off the push clips. Remove a couple of screws and unplug harness.
Mine goes under the B-pillar trim and into the trunk.
Thanks.
DrDJ
