STOPTECH OE Replacement Rotors now Available
Jay Herbert
Sunnyvale, CA
For: Immediate Release
PRESS RELEASE
Date: July 15, 2000
Contact: Robert Lee
High Performance OE Replacement Rotor for Viper Now Available Torrance, Ca. . . . STOPTECH announces the immediate availability of the high performance single piece AeroRotor TM for the popular Dodge Viper.
The AeroRotor TM , US manufactured to QS 9000 standards, is a 330mmx 32mm high performance single piece rotor. The AeroRotor TM is a direct OE replacement, which requires no modifications to the cars chassis, existing calipers or suspension and fits inside the stock wheels.
The AeroRotor TM with its unique patent pending vane design dramatically improves induced air flow (up to 64% over the stock Viper rotor) , reducing system operating temperatures under both normal and aggressive driving conditions, yielding less brake fade, longer pad life and more consistent, safer, controlled braking, stop after stop.
The design also has increased surface area by 12%, which helps the rotor transfer thermal energy. When coupled with the higher induced airflow, the result is the AeroRotor runs 10-15% cooler than original equipment rotors. The AeroRotor weighs 3.5 pounds less than the stock Viper rotor.
A Race quality proprietary cast iron formula is used to resist cracking and fatigue even under aggres-sive driving conditions. All AeroRotors are double disc ground and mill balanced for smooth performance and optimized pad break in right out of the box.
The Viper AeroRotor is the first in a series of Direct Upgrade one-piece OE compatible replacement rotors for popular sports cars, sports imports, SUV’s and other high performance street applications. The Viper AeroRotor is a direct bolt on replacement for any 1992-2000 Dodge Viper. Surface finishing is available in plain or slotted finishes. Silver CAD is available as an option.
Suggested retail prices start at $198.00 for plain and $230 for slotted.
Availability: Stock
For more information call Bob Lee at (310) 325-4799 or email at:
[email protected]
Ken Diemer
Holland, MI, U.S.A.
Autoform Development, Inc. also handles all StopTech products. StopTech brake systems and rotors are an excellent choice for most Viper owners. Please give Eric a call at (616)392-4909 for all of your brake needs. Autoform would also like to wish everyone a Happy Holiday Season!
webironmongery
