DavidSB
I put this up on the SRT-10 forum and no replies. Anyone here installed these, and can you advise?
David
I'm in the middle of installing Stoptech SS lines all around and have a few questions for anyone who's installed them on an SRT-10.
The driver's side rear line has a second brake line that screws into the top of the block fitting where the normal hard brake line meets the SS line. What is this and is there some other system that needs to be bled, and if so, how?
The front kit comes with 6 zipties and six 3/8" long pieces of hard rubber tubing. It would appear that these somehow replace the 3-per-side white plastic stand-offs that separate the brake line from the attached black wire (wheel speed sensor?). How are these installed to seperate the two: slit one side, open and snap over the wire, and ziptie them together?
Finally, since each caliper has two bleed screws, am I correct that you always bleed the outer before the inner as you work around from RR, LR, RF to LF?
Thanks in advance for the help.
David
'05 SRT-10 Silver: DC Performance Roll Bar, Comp Coupe Oil Pan, 5pt. Team Tech, X-Pel Clear Bra
Evo MR
E-350 7.3 PSD Sportsmobile
David
David
Evo MR
