storing wheels and tires ... a new solution
Luke@tirerack
Tire and wheel storage done right.
The Tire Storage Rack is a well-engineered solution to help organize the garage and keep extra tires or Tire & Wheel Packages out of the way. The flexible design allows room for today’s performance-oriented Tire & Wheel Packages or can be adjusted to accommodate less aggressive tire widths.
The adjustable rack quickly attaches to wall studs providing a convenient and safe storage method and its heavy-duty construction has been load tested to a weight capacity of 400 lbs.
you can use this link to find it on the website
Viper X
A 52-inch max innner width would be very tight with four Viper Tires in it, especially with 305 front / 335 or 345 rears. This rack looks like it could expand to be wider. Is that possible?
L
Luke@tirerack
yes it does expand ... i have seen OE Viper sizes in the "tire garage" product. "tire tote" product and even on the tire rack ... all fit pretty snug but do fit
305mm + 305mm + 335mm + 335mm = 1280mm = 50.39"
Catwood
I measured my Toyo's on forgeline wheels and total stacked on the floor they are 52.5". Stock wheels should fit with one but I suspect I'll need two racks. Then again...that's just room for more tires.
Catwood
FWIW...I was able to get all 4 of my tires up on the rack with room to spare.
I have 11" fronts with 305 toyos, and 13" rears with 335 toyo's.
I suspect lifting the stock rims and tires up is going to be a ***** though.
VenomXX
