Subwoofer grille removal advice
Peter Nielsen
Wilmington, NC
I understand the grille is just pushed on... However, I'm unsure if it's only the metal mesh part that pulls off, or does both the plastic ring and mesh pull off at the same time...
I tried to pull gently but it would not budge. I figure that I better ask somebody before trying again.
Reason for removing it is because the sub rattles - it sounds like the speaker wire is touching the cone...
Thanks,
Peter
08viperviolet
coral gables FL
it dose pull off but the best thing to do is to remove the rear plastic surround and then you get access to the speaker box. you can then remove the grill also.
GreatWhiteKAC
