Hi Everyone,
Just wanted to give you a little look at what we’re developing for the future.
The results below are of our standard Supercharger system (on a stock engine with bolt on upgrades) at 5 psi compared to our High Output upgrade kit with 8 psi boost, larger injectors, fuel pump voltage booster, etc. Tuning is not finished yet, but is coming along nicely (I was pulling out a little too much timing between 2,200 and 2,700 rpm).
Drivability and power is good. This particular run was done one 93-octane fuel mixed with 100 octane so we could add a couple of degrees of spark advance at the top. We we're trying to get a feel of how much power we could get at the top end. The stock engine was boost creeping above 5,000 RPM and the power was flattening out (engine couldn't flow what the Supercharger was forcing in).
Here are the actual and SAE corrected numbers from the two runs:
For comparisons, below is an older graph showing the engine output before and after the 5 psi Supercharger kit.
Sean
Sean
