Supercharging vs. Twin turbo
red98RT10
Greenville, MS
Can anyone tell me what the cost of adding a TT is (approx) to a Gen II...and what kind of power difference there is. Is there a big advantage of Supercharging vs.Turbo? Also, is there a lot of extra maintenance involved? I live in a rural area of Mississippi where most shops have never seen a Viper let alone being proficient in tuning or upgrading one.
Schulmann
Canada
Rural area ?! Then your issue will be to find good quality fuel. You will be limited with the boost. Beyond 700hp you can't feel the difference unless you ride above 120mph. You will have difficulty to put down so much force to the pavement.
Then what will you do with so much force on small roads ? Hunt chickens ?! Have a look on my picture in my archive. You will see what chickens can do ...
When you decided what you want, think about daily drivability and reliablity.
R
red98RT10
Greenville, MS
No racing fuel around here... just regular 93-94 octane is easily obtainable. We do have interstates so I don't have to just hunt chickens (although it is a common local pastime) but I rarely get above 120-130. Just looking for a faster 1/4 mile time essentially. reliability is VERY important though.
R
red98RT10
Greenville, MS
It's funny though, most people around here interested in racing are either in souped up pickups or stock mustangs. They have no idea.... :eek:
V 10 MAFIA
Twin Turbo Hands Down, You can always turn down the boost for better drivabiity. Better potential to make more power. Power comes later in the power band which helps in getting better traction.
peakcompletions
Texas
I have both a bad ass twin turbo car and a NA car for a couple of reasons,
I bought my car initially with a Roe S/C, due to a bad tune the car was hurt so bad that I had to rebuild the motor... in the process I decided to go with the twin turbo setup. Now, the car is awesome but not as driveable on the street as I would like.. in the west Texas heat and stop and go traffic I cannot run my A/C because the car heats to quick... even with the AEM and the boost on the lowest setting the car screams!
My NA car is a Venom 650R package dynoing right under 600 rwhp and rwtq (numbers are essentially identical within a couple of points). It has a really aggressive head and cam combo that sounds awesome, is super driveable, and still pulls hard! I can idle all day long with the A/C on, idle around town with no issues!
In short, for a lot less money you could have a head and cam setup installed and see how you like it... then add on later if you wish...
For everyday viper cruising my pick is my head and cam car... doesn't perform anything like the TT, but I save that one for special occasions! :)
Like spanking busa bikes.... hahaha
:2tu:
JohnnyBravo
Overland Park, KS
One of the major differences is going to be cost. The average twin turbo kit will run you around $25,000 installed and tuned. Heffner, Underground, RSI and Paolo Castellano all charge pretty much the same price for their kits.
On the other hand, a Roe supercharger can be had for around $7500 installed (with a couple hundred more for tuning). You won't make quite as much power on the Roe s/c as you will with twin turbos, but you might feel better having that extra $17,000 in your pocket.
I went with the Roe blower and water/methanol kit. I installed it myself (with the help of some friends). The car makes 564/594 through the stock manifolds and high flow cats. I'm taking it to Performance by Joe tomorrow to get a good tune on it. I'm sure it will end up being over 600/600 on pump gas when he's done with it.
I'd love to have a car that makes 800 rwhp+, but the difference between 6xx and 8xx wasn't worth basically the $20,000 pricetag to me at this point.
Just my $.02.
V10TT
Miami Fl
Peakcompletions, hwy doe your TT overheat vs. the NA car?, is it because the HUGE Front Mount intercooler?
the TT car has less compression for sure...
VIPER D
dutchess county, ny
on the average turbos can make the same hp with 3lbs less boost
there is no parasitic loss with a tt.
Theres 2 ways to look at that either
less strain on the motor for same hp
or
more hp at same boost level.
vd..
ps I have a blower and now upgrading to a rsi TT
GARY J
Turbo is the way to go. Call Jason Heffner, and there will be no "drivability" issues whatsoever.
I am currently building my third twin turbo viper.
STUGOTS
NY/CT
This one gonna be MORE power???????? (like you need it LMAO)
00prowler
Vernon CT USA
Remember if you go TT you are gonna need a set of Kuhmos to hook, Unitrax halfshafts and safety loops...Yes with a Roe S/C that wouldnt hurt either, but you can run Pilots with success, let em' spin and keep your stock halfshafts. The price can escalate out of control so be careful. I wanted to go TT, but felt it was too pricey for me...It is the baddest setup for sure, so if price is no object go TT...Al... :D :D
Casey
Valparaiso, IN.
You can't feel the difference beyond 700hp?
WHAT??
TT is the way to go! Covers all bases, and let's not forget, if you are afraid to use the max power of the TT, you can always leave the Boost Switch pointed towards your rear! :D
Earl_H
MI
TT ...see sig.. Once you go turbo, you'll never go back. Seen a lot of guys go from SC to Turbo, never heard of a guy going from Turbo to SC.
Dr Roof
Louisville, KY usa
I have had both and while supercharging is an excellent way of adding power they simply do not compare to the Twin Turbo.
The Twin Tubo is much quieter for street driving and far less maintance.
Twin Turbo will aslo be faster
BACKNBLACK
NY
I can say this.After driving Dimitios car which is all
ballz crazy, Iwould def stay with a super charger.Infact
super charge it adn throw a bottle of Nitrous 200 hot.Whose
better then you after that.You would have at least 1000 to
the crank!!!
that is the perfect setup if ya ask me.
roe s/c,10-12lb pulley,water ****,heads,cam,rockers, and a 100 shot of nitrous.
BACKNBLACK
NY
Hey to be honest, us guys in the south east really
shouldn't get into Turbo cars.I had this talk with D
yesterday. Can you imagine you send your car to get TT.What
happens if somethign goes wrong?I have to drive 2000 miles
to get it fixed everytime? I mean it's not the money but
the time of going back and forth would piss me off. I would
def stay with the Roe and just juice the sht out of it.You
will def have a car in the 9's..... :2tu:
THATS the only thing that would scare me away from a heffner or the other tuner in texas's TT car. im confident in thier work and that the car would come back to me in perfect working order. but now if for some reason it starts to run like crap....then what? off to florida or texas? that aint fun. just the down time alone would kill me.
Qualitywires.com
Louisville, KY
I'll sell my supercharger set up I built myself. Works pretty good..lots of power! :D
Sinusbeats
