I've always liked E85. The only problem is converting your car over. Since I've pretty much changed my entire fuel system I can run it. Although I just wonder if there's some seal somewhere that I missed will show up years later and start leaking
How much timing did you add when you tuned with E85?
Our basis for doing this and other testing is to show that e85 is the most cost effective, highest power delivered, at the pump fuel, for higher performance vehicles. It’s not a basis to show that it’s better for normal everyday vehicles. Our testing has shown that e85 performance gains are only realized once you reach a level of higher compression. Most of what we’ve tested has been TT systems and we’ll have results for NA higher compression very soon.
In this particular engine we ran 5 more degrees than what we ran on 93 octane.
The fuel system for this engine has a Flex Fuel sensor added inline. The sensor determines the amount of e85 or 93 in any combination that's present in the fuel lines. First we tuned 100% e85. Then we drained the tank and tuned 100% on 93. Then percentage compensations were made for combinations of e85 and 93. The flex fuel sensor communicates with the Motec ECU and the map adjusts accordingly to the combination of e85 and 93 present in the fuel lines.
Yes the fuel economy/mpg of e85 is 25% less because it requires that percentage more of e85 to run through the engine. When you add that 25% increase in cost to the average price of $2.00 gal. (e85) you get $2.50 gal.
Pulling up to the pump this engine can choose either 100% 93, 100% e85 or any combination of the two. If this engine chooses 100% e85 it will perform at a 50rwhp increase and 30rwtq increase over 93 for the same price as 93!
If you're looking at fuel economy/price and performance than lets add the 25% more and make e85 $2.50 a gal. I'm pretty sure you would see about the same results in performance if you added 104 octane vs. 93 doing the same 11.5 psi test with this engine. How much is 104 octane at the pump? I think it’s about double the price, not exactly sure yet. Filling up your tank for about half the price for the same performance is a substantial cost savings.
Fill up your tank for $36 or fill it up for $72 and get the same performance either way?
The Koenigsegg has an e85 setting that I believe is the highest power delivery out of the engine. The Lotus Exige just released an e85 S/C version that had a very interesting write up in Winding Road Online magazine:
Cool website -
http://www.windingroad.com/download?issue=new
I've been driving/testing e85 higher power/performance engines for over a year and I like the way the engines feel/run on e85 better than 93.
