I've used Amsoil for 30 years in many vehicles with excellent results. Probably close to a million miles. I put Amsoil in the Viper tranny a little over 40,000 miles ago. Replaced it with 32,000 miles on it this past spring. This lube had 5-6 track events, about 15-1/4 mile passes, and at least 25 autocrosses on it. Oil analysis showed it to be in very good shape and easily capable of longer life.
As for observations: Shifting is extremely smooth with absolutely no 1-2 problems hot. (of course I don't recall any problems with the OEM fluid on the 1-2 shift prior to changing) The short throw MGW shifter is cooler than it was with the Castrol in hot temps. In fact, after also changing the rear end to Amsoil 30,000 miles ago, I think the water temp dropped a couple needles worth. I will test this theory again when I swap out all the OEM fluids next week in the new 2001 GTS/ACR we just bought. The cars are pretty much identical drivetrain wise except the 2000 car has a 3:45 Unitrax rear end and the 2001 car has a stock rear end with a 19" wheel package---effectively dropping the rear end ratio to 2:92. The new one is definitely running hotter than the 00, although not abnormal. It's now between the 2-3 bars at freeway speeds and 70 degrees or so. The 2000 car was about the same but dropped to well below the first bar under the same driving conditions. If anything the 3:45 gears would contribute more heat to the equation
Steve
