I'm thinking about installing a Hurst shifter, might as well change the tranny fluid at the same time. Anyone know if the stock tranny fluid is synthetic or not - if not, any suggestions on a good synthetic fluid to replace the stock fluid?
I assume that you mean a Gen III (though the systhetic fluid came with the 1999-2002 as well...labled as "Castrol Syntorq in the owner's manual)...yes, the "factory fill" transmission fluid is indeed "synthetic"...specifically Mopar's "Synthetic Manual Transmission Lubricant 75W/85".
Listen to Stevie , he is a master of fluids. Is your car new, or how many miles are on it, as this would determine if you should change it ( along with a visual inspection). I would follow Steve's thoughts and you are safest just using factory.
Use the Castrol Syntorq. It is the factory fill. It can be hard to find other than at dealers. It takes the heat extremely well, which is critical in this car.
Yeah, I should have clarified - mine's a 2004 with 10K on it, the only reason I was considering changing tranny fluid was if the stock fluid was not synthetic I thought it might benefit to put synthetic fluid in it. Appreciate the posts, I'll leave it alone until it needs to be changed, thanks!
