steve911
Here's the scoop. Just bought a new K&N sytem for my 04. I was removing the factory setup, and while things were apart I wanted to check the tightness of the new high pressure Power steering/fan hose. (If you recall I had one fail catastrophically at 130+ mph). LOTS of SMOKE and a small momentary fire to boot.
After the hose fittings checked out fine, I instinctively reached down to the balancer bolt and HOLY CRAP, its finger loose and out about 2 turns. My question today is, DO I need to take the tension off of the serpentine belt to find out if the balancer is either loose on the crank, or slid partially out from it normal position. I can't really get a clear view of the pulley to see if it is in alignment.
thanks in advance.
thanks in advance.
