There are actually a few other options out there:
Pirelli PZero Rosso in sizes that are slightly different than stock but should not impact overall tire diameter and therefore speedometer or gearing. For example, the Pirelli makes a 355 mm width tire. Other board members have used this tire. See
www.tirerack.com for sizes and for performance in relation to the stock Michelin Pilot Sport ZP (Zero Pressure) tire.
Hoosier has also just come out with their new autocross and race tires in stock sizes. Again, see tirerack. Note: these are basically racing slicks so I assume this is not what you are after.
Also, if you are willing to change rims (going to 20 inch rims in the rear or, using an emergency brake relocation kit, going to 18s in the rear), you can use the new Michelin Pilot Sport PS2 (arguably the best all around street tire currently available) or the Michelin Pilot Sport Cup (track day/ dry street tire).
Not to hijack this thread, but I am interested in the debate about using the stock ZP tire versus the non-runflat Michelin Pilot SPort at the track: TireRack believes that the nonrunflat will be better because of weight savings and also because the runflats "take away the feel from the suspension." Can anyone with firsthand experience with the two tires comment? I would tend to agree with that view but am also concerned about deviating from the stock tires (e.g., suspension was tuned at the factorywith these stock tires in mind).
Thanks for your input.
/Rich
