torque specs for wheels nuts, 96 gts
DrumrBoy
GA
Spec Is 95 as VJ says, If you're beating on it (as on a road course) I'd do 100-103 cold.
Bonkers
DelaWhere? USA
Back in the day I was told by two reliable techs at ViperDays that
they would never tighten to more than 95tq - anything more than
that leads to the studs breaking under extreme load. That was many
years ago (and I may be misquoting,) but I still take it to heart to
this day and never once had a problem.
Dan Cragin
LA, CA
I agree with bonkers, 95tq is as high as I go. The most important thing is that the the wheel studs are all tight and evenly torqued. I clean the threads on the studs and the mounting surface of the hub with a wire brush, then I put a small amount of lubricant on the studs (some disagree with this, but its worked for me).
The biggest problem I see in the field is over torqued or frozen lug nuts. You cant get them off or the stud breaks.
With new studs, or new wheels, you should re-torque them after a few miles.
Just my experience, your may differ.
SKY1960
