Torque specs needed
Bolt
Harrisburg, Pa
Anyone have the torque specs for a Gen II motor. I'm looking for the full list. I did a search here but could not find anything.
While I have always tried to promptly post answers to this type of question, this one exceeds my desire to type!! I would recommend that you get a Service Manual ASAP...preferably before you take your engine apart.
That said, did you have a particular year in mind??
B
Bolt
Harrisburg, Pa
This is what I am looking for but for the Gen II
2004 8.3 v10
TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs.
A/C Compressor Mounting—Bolts 23 — 200
A/C Compressor Bracket—Bolts 23 — 200
Camshaft Position Sensor—Bolt 11 — 95
Camshaft Sprocket—Bolts 23 — 200
Camshaft Thrust Plate—Bolts 24 — 210
Connecting Rod Cap—Bolts 68 50 —
Crankshaft Main Bearing Cap—Bolts (Refer to CRANKSHAFT - INSTALLATION)
Crankshaft Oil Scraper—Nuts 23 — 200
Crankshaft Pulley—Bolts 23 — 200
Crankshaft Vibration Damper—Bolt 176 130 —
Cylinder Head—Bolts (Refer to CYLINDER HEAD - INSTALLATION)
Cylinder Head Cover—Bolts/Studs 11 — 95
Exhaust Manifold 23 — 200
Exhaust Pipe V-Band Clamp 11 — 100
Engine Mount Bracket-to-Block—Bolts 41 30 —
Engine Mount Insulator—Nuts 102 75 —
Flywheel to Crankshaft—Bolts 75 55 —
Generator Mounting—Bolts 41 30 —
Intake Manifold—Bolts 11 — 95
Oil Cooler—Bolts 5 — 40
Oil Cooler Line Fitting 68 50 —
Oil Pan—Bolts
1/4–20 11 — 95
5/16–18 23 — 200
Oil Pan Drain—Plug 34 25 —
Oil Pressure Relief Valve—Plug 34 25 —
Oil Pump Cover—Bolts 23 — 200
Oil Pump Pick-up Tube
Bolt 1/4–20 11 — 95
Nut 5/16–18 23 — 200
Oil Filter 18 — 160
Oil Pressure Sensor 8.5 — 75
Oil Temperature Sensor 8.5 — 75
Power Steering Pump Mounting—Bolts 23 — 200
Rear Crankshaft Seal Retainer—Bolts 11 — 95
Rocker Arm—Bolts 35 26 —
Spark Plugs 27 20 —
Starter Mounting—Bolts 41 30 —
Throttle Body—Bolts 11 — 95
Timing Chain Cover—Bolts 23 — 200
Water Pump Mounting—Bolts 11 — 95
SquadX
VA/MD/DC
I was going to say call me and I would read them to u over the phone but thanks Dave. U saved me N hr or so.
Rot8te
