track alignment
Gavin
Monterey, Ca, USA
Searched this site for any information regarding the appropriate wheel alighment setup for the track but no luck
I'm looking for something fairly agressive
Gavin
G
Gavin
Monterey, Ca, USA
Chuck - I knew I could count on you!!
Now how about cutting loose with toe in numbers - same for camber
Gavin
JoeB
Danville, CA, USA
Gavin,
I see your taking my advice,
Here you go. These were posted by So Cal and he got them from Woodhouse.
#278666 - 05/28/03 03:28 PM Edit Reply Quote Quick Reply
Andy is right with his #s as far as a street/track setting, removing the sport shims will give you another -1 degree of camber up front. I never bothered with them.
Front caster:
left 5.84 right 5.99
camber
left -1.9 right -1.9
toe neutral
Rear camber
left -1.4 right -1.4
toe left 0.11 right 0.10
Viperless (for now)
RON
Joe B
Chuck 98 RT/10
tampa, fl USA
Here's what I've been running. Recommended by a fast tracker from Texas. You can't street with an alignment like this, unless you have some flatspotters you don't care about (which I tend to have plenty of). Take one look at the camber from the front of the car and you'll see why.
camber at -2.2 to -2.5 front, -2.0 at the rear. Caster at stock settings - Toe - 1/8" out up front, 1/4" in at the back (total.)
I went with the low end on the camber settings but I'm thinking of going with more. But I'm just some guy having some fun. The VRL guys would be the ones to tap for this info.
jrkermode
Los Altos, CA, USA
These are not the agressive settings you were looking for, rather some numbers for comparison. These were recommended to me by Bill P as about the most you could go on the street.
Front Camber: -1.5 degrees
Rear Camber: -1.1 degrees
Front Caster: 6 degrees
Front Toe: 0
Rear Toe: 1/8 in
Front Pressure: 34 psig
Rear Pressure: 30 psig
SoCal Rebell
Mission Hills, Ca USA
Gavin,
Front caster:
camber
toe neutral
Rear camber
Viperless (for now)
RON
Joe B
I can tell you from experience the above #s are about as aggressive as you can get and still drive on the street, but Chuck's right if you want the most aggressive you can get it's his #sn but it'll be a ****** on the street.
WCKDVPR
San Jose, CA USA
Gavin,
Here is my chassis set-up for Hoosiers (F 305 & R 335). Alignment settings based on tire temps.
Front:
Camber -2.25 degrees
Castor 7 degrees
Toe 1/16 out per side
Rear:
Camber -1.75 degrees
Castor 1.0 degrees
Toe 3/16 in total
Ride height: (to frame rails at centerline of wheels)
Front: 4 3/8
Rear: 4 3/4
Springs:
Front: 550
Rear: 900
Best regards,
G
Gavin
Monterey, Ca, USA
Thank you everyone - this gives me lots to work with - very much appreciate your time.
Mike - when will we see you and the GTS back on track?
Gavin
Fast Viper Dan
Saratoga, CA, USA
Gavin,
Are you interested in going to Button Willow Oct. 9,10. With a bunch of VCA members.
Dan
Go with Mikes numbers, I know it takes more than numbers but he is fast!
tbone96
