18 inch SSR Comp wheels: 13 inches wide in rear, 11 inches wide in front. Very light weight, but you will need to relocate the e-brake in the rear (not hard to do with the Archer kit.)
Michelin Pilot Sport Cup tires. Much lighter and much more sticky than the stock tires. They wear extremely well for a competition tire, and will last at least two to three times as long as a typical "R" compound tire. They take a while to heat up, however, so you will need quite a few hot laps before the tires achieve maximum grip. When cold, they have less grip than the stock tires. (this makes them great for track days, but lousy for autocross)
This is the set-up I use. The new tires and wheels give the car much increased performance at the track, both because the tires add grip, and the wheel/tire combo is about 20 pounds PER CORNER than the stock set up, which makes your suspension work better. Cornering and braking are significantly better. You will have to decide for yourself if the cost is worth it.
