Transmission needed
Dann
California
Hi. I'm looking for a transmission and bellhousing for a 98 engine. I know it's a Gen 2 and would like to know what years of Viper transmission would be a direct fit also. A T6 would be fine, but if a newer stronger transmission will fit, I would consider that as well. Any source would be appreciated also.
Thank you in advance, Dann
T-56 was OEM.
Call Rodney at RPM Transmissions in Anderson, In. He likely has something in stock...can can discuss options with you.
Tom and Vipers
Jeannette, PA 15644
I've thought about upgrading my 96 GTS for better shifting (not strength) with double and triple cone synchronizers. The T56 suckz ballz with single cone synchros that were designed for 4-speeds w/o the additional "two gear's worth" of extra rotational mass not to mention a huge single disc clutch.
GreatWhiteKAC
