TSB's
eliems
Vancouver BC
The only info I got on my new car was that there were no outstanding recalls. Have many or most of you been through these Technical Service Bulletins and are there any that I should worry about?
Automotive Recall and Technical Service Bulletin Titles for 2000 Dodge Viper RT-10 V10-8.0L VIN E.
TSB Number & Issue Date TSB Title
999 MAY 02 Recall - Steering Gear Crossmember Reinforcement
957 NOV 00 Recall - Child Restraint, Owner's Manual Update
876 MAY 00 Recall - Cooling Fan Continuous Operation, PCM Update
23-014-06 MAR 06 Wipers/Washers - Wipers Smear or Streak Winshield
18-037-05 OCT 05 Engine Controls - Flash Programming Failure Recovery
18-029-05 JUN 05 Engine Controls - Co-Pilot Support & Correct Cable Usage
19-005-03 AUG 03 Steering - Power Steering Fluid Usage
24-003-03 MAY 03 A/C - System Sealer Usage Prohibition
18-019-03 MAY 03 Engine Controls - Spark Knock Using High Octane Fuel
24-009-02 OCT 02 A/C - System Leak Detection
08-010-01 MAY 01 Airbag/Clock Spring - Service
08-006-00A DEC 00 Wiring - Revised Splicing Procedure
26-03-00D MAR 00 Fuel System - Fuel Delivery Service Procedures Update
09-04-00 FEB 00 Engine - Replacement Break In Procedure
18-01-00 FEB 00 EVAP System - Leak Detection Pump Misdiagnosis
My RT has 29,000 miles on it now and seems to be perfect mechanically.
Madduc
Fremont,MI
The only one I'd be concerned with is the 999 recall. Most likely it has been done, so you should be good to go. Just about all of those TSB's are for the tech's to properly service your car. Like which power steering fluid to use, not to use a sealer in the A/C system, how to splice a wire they cut, how to service your fuel system, etc. None of them that you would need to worry about. Enjoy your car, and also join the VCA.
newredrt10
Administrator
Warren, OH
There is a piston ring re-call for early 2000 motors that you don,t have listed. The problem is that the rings never seated. If you car is using any oil it maybe a candidate. There are manufacture dates on the block. If they are late 99 manufacture Sept. to Nov check with a Good Viper dealer (if any are still around-- They closed all around me). If the dealer does not know what your talking about call some one else/like Woodhouse, he fixed mine
No members online now.
TheHunter
