Turn Signals/ Hazards not working
PS78
UK
2002 RT/10
Just a last ditch rfi here before handing over to the Dodge tech... Both indicators, hazards and relevant message centre/direction lights don't work.
All fuses under hood and above footwell are fine - checked and double checked with replacement fuses.
Can someone please tell me what the '(3) BULKHEAD CONNECTOR' is?
When i first unscrewed the MULTI-FUNCTION SWITCH connector, the switch face had an oily/greasy residue on it....I guess this isn't normal!?
Also, there is a 'Flasher Smart Relay' socket adjacent the interior fuse board. Is that relay meant to be missing (has been since before my ownership)?
There is resistance (/ no continuity) between a few pins on the switch, so it's looking most likely being the switch, but i want to rule other causes out before getting a new one.... Any ideas on cost from Dodge, before the Monday morning call?
Many thanks for any help!
PS78
PS78
UK
MULTI-FUNCTION SWITCH CONTINUITY test
PS78
PS78
UK
Not yet Madd... Thanks for your comment. Are these relays cheap?...sure i'll ask on monday too. Have you had this problem before?
PS78
PS78
UK
right..relays are cheap! :) but, bit miffed...should there be one in the t/sig haz flasher slot?
if so, how could the lights have worked before?
and what is the silver cylinder (relay?) in the photo above next to the yellow relay?
Many thanks for any help ;)
Madduc
Fremont,MI
My 97 looks just like yours. No relay above the yellow one, just the silver relay above and to the side. Haven't had this problem on the viper...knock on wood!
PS78
PS78
UK
Cigar lighter doesn't work and is on the same fused circuit...but the fuse isn't blown...Has anyone encountered this situation before?
General Jackson
