Viper Down on Power
fireball
A friend of mine has a problem with her Viper. It felt way down on power so she brought to the dealer and they said all was OK. She's since had it dyno'd and it puts out 230hp at the wheels. She was certainly correct - it is down on power.
She went back to the dealer and they said they checked everything and all was OK but they suspect something mechanical since all the electronics checked out OK.
There are no other symptoms, no noises, no smoke and it starts and runs fine - it's just down on power.
Any ideas? I'm thinking valve spring.
I wonder how many trips to the dealer she needs to make before they pop the valve cover off?
Thanks,
Greg
Westxsrt10
Boise, Idaho
Thanks,
Greg
First thing that comes to my mind is plugged catalytic converters....
ulllose
Brunswick, Ohio
They must have dynoed only one rear wheel........:rolaugh:
I'm assuming the dealer took a good look at the car. Did they drive it?
What year is the car how many miles?
If you come back and tell me its a 92 with 300K on it well........;)
2001-V10 Power Nut
Florida
Haines City, Florida, heck he might have a 1100 hp Corvette "Swamp Buggy" LOL, and you still claim him a relative even though he has a Corvette?:rolaugh:
black mamba1
CT
She should do a leak down test. Also, did she buy the car second hand? There might have been mods that reduce the power. If the motor was built for boost, the c/r might have been lowered, cam changed, tuning changed, etc for boost. The seller might have removed all the boost hardware, leaving a car that might run really anemic w/out the correct set up. That is something the normal techs at regular Dodge dealerships will probably miss.
just my .02
F
fireball
Thanks guys. Sorry about the lack of info.... I just forgot. It's an SRT-10, 2004 with about 15,000 miles.
The cats eh? Good idea. Could be
A leak down test wouldn't hurt, I'll suggest it
It's not a Vette motor (thank God!)
The clutch isn't slipping
They dyno'd both wheels
She bought it new and made no mods
I'll forward this information. I really think that any Viper that only makes 230hp.... it should be obvious what the problem is. The dealer says they've checked it but jeez - this one should be easy.
Thanks again.
Viper X
Could be cats, just not likely. Shouldn't loose that much rwhp with slightly clogged cats and factory cats should be good for more than 15,000 miles.
A leak down test would be a good idea. Likely valve related / compression related (lack thereof).
Good luck,
Dan
F
fireball
Thanks guys.
A leak down test should give some good information.
I'll be away from my computer for a couple of weeks but I'll let you know what happens.
GreatWhiteKAC
