Viper front end alignment.
alexander m embry
Got a quote from a dodge dealer for an alignment and they quoted $400. I know there are several measurements they are suppose to do but is that really needed. Has anybody taken the Viper to a local shop? My front tires wear on the inside really bad.
Dan Aseere
Mason, Ohio USA
A performance company does mine for 200. The inside wear is caused by Dodge setting up the specs for better cornering but the tire does not wear square at this setting.
The Dodge dealer will likely do it by the book. At their shop rates, that's about right. If you're just looking for front end work, I'd take it to a GOOD regular alignment shop.
Asp Man
Kelowna B.C., WEStern Canada
+1.
If you go to an independant shop, make sure that they have the equipment to do the aligne on the Viper. Older set-ups/machines will not be able to do it due to the air dam.
As well, make sure they weight the car per the shop manual. It will make a difference. A lot of shops will just set it up "static" and call it a day.
Another tip, make sure the guy knows what he's doing. Ask questions, they're typicaly free, parts and fixes aren't.
Rollin4
Anacoco, La.
Dan is correct. A factory setting wiil wear inside of the tires, it's normal.
happy
p.e.i canada
got mine done all 4 after it was fixed for less than a 100$ and its perfect steering wheel is straight and drives very straight as well! 400$ seems ver very high!! It only took them about a hour to do!
Viperless
MN
Shop around. I was quoted $350 for corner weighting and alignment by a reputable race shop.
RobHook
Washington, DC, USA
If I remember correctly, the official Dodge method requires that they set the bump-steer too. I haven't looked at the procedure but I think setting this makes it harder by a few orders of magnitude. Plus there's a special guage and height tool that are supposed to be used when aligning the Viper. I have them somewhere.
benson8708
I have lifetime alignment from Firestone for 150 buck and they will align it to the specs I tell them. So if I am going to the track I take my car in and they align it to track specs. Then a few days later. I take it back in and they put it back to factory specs.....FREE. Forever unless the economy takes them out.
99VPRGTS
Panama City, FL
Got mine done for about $70. The guy has been aligning cars for 30 years and has done quite a few Vipers. I watched him do the entire thing and I don't understand what the big deal is. He got around the bumper just fine. He did have new Gemini (I think that was the name) equipment so I'm not sure if that helped or not. Car rides/handles better than it did and I got it done almost a year ago.
xeng yang
