Viper GTS wheel Fitment
tito#14srt
Tampa, FL
I bought a set of CCW wheels they are in the process of polishing now should have them in a week or two. Anyway I went with the SP600
19x11 front and a 20x13 rear I plan to drop the GTS with coilovers and was wondering what tire sizes are you guys running.
I was thinking for the fronts 19x11 a 295/30 19"
And for the Rears 20x13 a 345/25 20"
Will this work? Thanks
tim721
west milford, nj
You should have no problems there. 25 profile on 20s in the rear is key.
I have 345/25/20 rear and 285/30/20 front lowered with no issues
The Invos are great
T
tito#14srt
Tampa, FL
Do you think I am better off running same tire up front like you have 285/30 19 do you think if I go with a 295/30 19" it might be too wide and rub I dnt think its much of a difference.....
Do you have any pics of your ride you could post up? Thanks
Timnineside
West Michigan
I run a 295/25/20 fronts so should be close. Fit my GTS and my 08 coupe. Also ran a 345/25/20 rear's on both cars. No issues on the GTS however my 08 rubs every so often.
Both cars lowered on Eibachs only.
KNG SNKE
Portsmouth, Rhode Island
Pretty sure my fronts are 285's. 90% sure, but I am at work now. Here is a link to the sizes your asking about
19/20 setup, 285 front, 345 rears.
More photos in other albums.
KNG SNKE
Sweet ride bro! Those are ccw sp600 also are they not, just in black?
Yes, sp600, that is why I posted the photo, to give you as close as possible to a representation of what your vehicle will look like (Please note that I am lowered on spring caps only). The ONLY issue I have had is I had to install a spacer in the back, 1/8 inch, due to my big brake kit, and the end result of the spacers made my wheels rub on hard bumps, exactly 1/8 inch of rubbing. :).
T
tito#14srt
Tampa, FL
I want to drop it using coilovers so it will be sitting pretty low, lower then eibachs.... I dnt know how low I can go with a 295 before I run into rubbing issues mainly when turning up front, would a 285/30 19" tire be strecthed for a 19x11 wide wheel?
T
tito#14srt
Tampa, FL
What size spacers do you have? I spoke with one of the guys at ccw and they told me if I needed a spacer for the rear he would put it together in the package...and I know I will be needing them since I will be upgrading to a big brake kit.
KNG SNKE
My fronts are 19x11 and they are 285/30/19, just verified. My tire is definitely not stretched.
I ONLY run spacers because I upgraded my braking system to all SRT brakes. If you do have plans to do the upgrade you will need a 1/8 inch spacer for the rear. If your keeping stock calipers there should be no issue. This upgrade WILL limit how low you can slam the vehicle due to slight rubbing on the wheel well.
T
tito#14srt
Tampa, FL
Thanks for all the helpful info...I will make sure to have them include a 1/8 spacer with my order because I will be upgrading the brakes. And I guess im going to go with the 285/30 19" fronts.. love your gts looks killer bro!!
KNG SNKE
TY. This angle really only shows off the wheels and stance. Feel free to check out the other photos in my photobucket. Lots of pictures of the wheels.
rlamorte
