Viper wont start... or well anything...
Bonkers
DelaWhere? USA
Installed a new diehard six months ago, been on the battery
tender ever since. Went to get in yesterday... nothing. No
power at all. Its under the lift right now so I cant get to the
battery itself, but I tried to start and jump it off the hood
terminal and could only manage a weak click. Left it over
night on the new charger, the doors popped open, but that
was it - instantly dead again.
Im in a pickle now because my keys are locked in and I
dont have access to the hatch and I cannot jack it up. Is
there a fuse or something preventing charge on the hood
terminal? This has happened before but would always
start on a jump - even with a bad battery...
Bonkers
Bonkers
DelaWhere? USA
Excellent plan... except I cant get to the battery until I move
the car from under the lift. Cant move the car until I can get
inside. Cant get inside until I get enough power to the doors.
Right not I cant get any power through the hood terminal at
all...
AZTVR
Chandler AZ
all...
Can you use a floor jack to lift the car from the differential, lift the rear wheels off the ground, and pull the car out? (Assuming that it is nose in.)
Bonkers
Bonkers
DelaWhere? USA
No wheels are turned from when I pulled in...
The question I need answered is whether or not there is a
reason the underhood terminal is not working? Usually the
door poppers work once a power source is connect - not
this time. If there is a fuse or something I might be able to
get to that - if not I'll have to get the tractor out and drag
her out.
... its not that im opposed to doing that either, I just dont
like the brute force method if flipping a switch will solve
the issue. I tend to break things...
Bonkers, if you have a shorted cell in your battery, you may never get it started from front terminals. Likewise, if cable has nearly corroded through at battery terminals, nearly same deal. Call me 317-402-9013
Bonkers
Bonkers
DelaWhere? USA
She suddenly decided to power up and run... just long enough
to move the 10ft I needed to clear the lift for jacking her up.
New Optima on the way... She's tapping baddly under the hood,
but I think I remember Tator telling me something about the
valves tap if she sits for too long... either way, problem for
another day. Thanks for the offer anyway - one more weekend
completely shot...
ViperJeff
Legacy Member
Idaho
She's just telling you she needs more of your time than your giving her now :)
