Finally broke 2,000 miles on the GTS and am going to change the spark plugs. So i bought a compression tester so i can get baseline numbers for the future. I decided to give the Zr1 a tune up and compression test also before it goes on its merry way.
I look up in the viper manual and it just says to remove all plugs, etc, etc,- No big deal.
Look in the ZR1 manual and says that before doing compression test 'Engine should be at operating temperature, remove spark plugs, etc etc'"
Then as we all know for aluminum heads we should allow the engine to cool before removing spark plugs or the threads in the cylinder head may be damaged. At least that's what the corvette manual syas.
Looked at the instructions that came with the compression tester and it also says the engine should be at operating temperature.
So i ask you, what is the right way to do a compression test?
Thank you .
Thank you .
