What is the Torque spec for the Diff to frame bolts?
klamathpro
Detroit
Yes I searched. What is the Torque spec for the two verticle differential to frame bolts on a GEN2? I only have a 95 manual and it shows the ladder bar bolts being torqued to 150ft-lbs. But GEN2's don't have a ladder bar and bolt to an adaptor that's attached to the frame. I just want to make sure its to spec while I am installing my Woodhouse mounts. I set my torque wrench to 90ft-lbs and the bolts are tightening down more. 150ft-lbs seams excessive for that webbed alluminum at the front of the diff.
Omaha NE.
Bearing Cap Bolts88 N·m (65 ft. lbs.)
Diff. Cover Bolts47 N·m (35 ft. lbs.)
Diff. Mount. Bolts135 N·m (100 ft. lbs.)
Pin. Crossm. At Bracket135 N·m (100 ft. lbs.)
Pin. Crossm. At Axle135 N·m (100 ft. lbs.)
K
klamathpro
Detroit
Thanks. I'll assume they are the Diff Mount Bolts. I'm glad I didn't use 150.
