What rearend do we have? Can we use a TA Girdle Cover? ---
alwayscode390
STL
I run the TA girdle covers on all my solid rearend cars, but wasnt sure if they made one for the independent rears that we have.
It stiffens up the pumpkin, and puts preload on the main bearings.
What rearend do we have, what is it called ( IE. Ford 9" , Chevy 10 or 12 bolt, ect ) ?
If we can run one, whats the part number I am looking for?
When they have the cover off, I will have them check to see what rearend gears I have installed ... they can count the teeth and figure it out , right?
MoparBoyy
Apopka, FL
umm.. have you not looked under your car before?
MoparBoyy
Apopka, FL
rear shot. in order to get the cover off to look at the gears you have to take the whole thing out. not sure why you would do that just to look at it.
A
alwayscode390
STL
I just got the car a week ago and havent crawled under it all the way yet.
I want to look at the gears because I am not sure if I have 3.55's , 3.73's, or 4.10's
I found a receipt from the previous owner stating "gear install" ...
So to answer my original question, there are no TA girdles for these rearends hahah ---
MoparBoyy
Apopka, FL
congrats on the new ride.
you can just jack it up, spin the tires, count the driveshaft rotations. i
A
alwayscode390
STL
I actually asked another member with 4.10 gears to tell me what mph he was pulling at 4th gear / 2000 rpm ... we are both at the same speed , so I guess I have 4.10's.
Thanks ... my car is actually out of Orlando, I see you are in FL ... are you active in a club around there? You may know it , lol !!!
Where is the oil fill and drain on that rearend, is it a pain to swap fluids? I cant see it in the pics, unless its in front of the right axle in the first pic ---
MoparBoyy
Apopka, FL
i've only been here a year so i dont know too many vipers in this area. all the fluids are easy to change, the fill and drain are right on the side of the diff, can't miss it.
A
alwayscode390
STL
How do you change the fluids ... you have to take the entire rearend out to take the cover off? ---
Stonep185
Ft. Worth, TX
To change the diff fluid you can either use a suction method to draw out the fluid then replace it through the same hole. Or there is a how-to with details to make a drain hole in the diff. The fill plug is on the passenger side and uses a 3/8 allen wrench to remove.
Stonep185
Ft. Worth, TX
If you choose to use the suction method I found it is easier to have a helping hand to operate the hand pump (unless you are fortunate enough to have a Midyvac available) while another fishes the tube down in the diff. I was not able to get ALL the diff fluid out but I got 28 of 32oz out. The drain plug may be put on my to-do list in the future. Expect to make a mess with this fluid change!
MoparBoyy
Apopka, FL
WHAT?!?! theres a drain!
MoparBoyy
Apopka, FL
see picture, you can drain the fluid thru these holes. then use the fill plug to fill.
A
alwayscode390
STL
So, those drain plugs in the pic he posted were modified into the stock rear end , right? I cant see your link yet ---
Mopar Boy
Ontario and Ohio
THANKS ... I added my cars VIN to my profile ... but I am still an "enthusiast" ... how long will it take to make me a VIPER OWNER? Should I pm someone like a moderator? :) ---
Join the VCA ;)
The other MoparBoyy is right. Join the VCA and you will not only get the title, but the Viper magazine, access to "hidden" parts of the forum, membership to your local chapter, ability to buy raffle tickets, etc.
A
alwayscode390
STL
Im currently in contact with my local chapters president ... will join soon :)
I have a 2001 GTS , did some years have drains and some not in the Gen 2's? ---
Camfab
SoCal
The Mopar Performance differential came with the additional holes on the bottom to accommodate the Mopar Performance diff cooler unit. You may be able to find some differentials out there but the cooler package has been gone for many years. My avatar photo shows a Mopar Performance diff. with the two holes at the bottom.
Camfab
SoCal
the pic i posted they sure do look factory since there's machined surface around them.
The pic you posted is not a GEN II diff. nor is the first diff picture you displayed (post #2). Your post #3 is a Gen II diff.
MoparBoyy
Apopka, FL
The full diff pics posted were to show the mounting of the rear cover not exactly what the diff looks like, they are obviously two different diffs. Man there must be a ton of lucky guys out there that got free MP diffs in there Vipers.
Camfab
SoCal
Actually I don't think they sold many of those differentials. As far as factory performance parts go, they were a great deal. I think I paid $1100 for mine at Woodhouse 8 yrs ago. I wanted the cooler assembly as well but they had discontinued them.
VenomXX
