What spark plugs for heads/cam setup?
98intrigue
Clearwater, FL
I have an '06 coupe...I'm finally installing my TBs, headers, and exhaust that I've had for months and will get the car tuned ASAP. I had the heads/cam done in May and am just now getting to finish the car due to a couple setbacks.
What spark plugs are recommended for 150whp over stock?
ACPERFORMANCE
Murrieta CA
Received your text and sent you a reply...gauge from the ******** the plug...you can start with a stock plug. Depending on how it looks, there's a chance you could end up one heat range colder. Your bump in compression may or may not be as big of a jump as you think, which in turn may or may not call for the cooler plug.
Let the plug signs tell you.
Todd
xeng yang
