What's the hat height of the Gen III rotors compared to Gen 2?
Irid
What\'s the hat height of the Gen III rotors compared to Gen 2?
Is the 14" gen III front rotor identical to the 13" gen II rotor, save the extra inch of diameter? Or is the hat height or mounting offset different?
Directly: will the gen III 14" rotor mount up to a gen II front hub assembly, assuming the brake caliper is moved out half an inch?
Skip White
Kingsport TN
Re: What\'s the hat height of the Gen III rotors compared to Gen 2?
Don't know, but I do know the GenIII rotors have different hat heights from the front to the back rotor. About a 1/4 inch or so. I'll have some all aluminum rotors for your car soon, that is with a steel friction surface on them. I think the 14 inch cast iron rotor is a sin to use. They weigh a ton.
Check out the projects page on my site. www.provipermods.com
Skip White
jpolen21
