Where to Anchor a Six Point Harness?
Omaha NE.
There are threaded insert in the tunnel and the factory ones on the outside. We use the snap in hardware for easy removal. The shoulder harnesses anchor under the panel behind the seat, pry it open and you will see it. The sub strap mounts either to the rear seat bolts or to the lap belt anchor points. A 5pt will require you make a bracket that goes from the front two seat bolts and mount in the center.
Hope that helps.
Jeff Monheim
No pictures well not complete at all but it is very simple go to your car and call me I will walk you through it while you touch and look then you will under standvery easy.
The five point harness will not comply with many track day event safety inspections. "crotch" belt 5 or 6 point must come from behind the driver or through the seat but not from the front of the seat!
CT GTS SCUBAPRO
Hawley, PA
I think that I answered my own question. There are no holes in the floor. I t looks as though by the above photos that they mount to the front seat braket bolts.
Phoenix SRT
Dale04SS
