Wideband A/F Alarms?
ViperRichRT10
Suwanee, GA
Anyone ever seen an wideband air/fuel alarm? I have an innovate wideband with a digital guage. It doesn't take going lean long to have a problem as I know too well. I was wondering if anyone has an audible alarm that can go off at a preset limit? Is there such a thing?
Thanks,
Rich
Schulmann
Canada
I had also similar concerns to run lean but most often you end-up running too rich ... Tune your Viper so it will run alway on the safe side.
Jack B
NE Ohio
The Innovate gauge can be programmed to alarm using filters. You should set it up to alarm at greater than XXXX rpm for XX a/f ratio.
V
ViperRichRT10
Suwanee, GA
Jack,
I have a digital guage that is very small and not an innovate guage. It is hooked up to an innovate unit however. My digital guage is from www.dynotunenitrous.com . Which guage are you refering to and where did you get it?
Thanks!
Jack B
NE Ohio
The innovate XD series gauge. I mounted mine in place of the oem charging system gauge.
xeng yang
