Wideband help
martyb
IL
I am working on installing an NGK Powerdex wideband. Got everything hooked up, and I am trying to calibrate the unit. Getting 8888 across the display, when it should say CAL or AIR. Any ideas? I am going to check power to the sensor now, but the damn thing is brand new!!!
Steve 00RT/10
Michigan
I have 2 of these for a while now. Both work very well. I take the WB sensors out every spring and do the re-cal procedure. They have never needed any adjustment.
I assume you have the WB hanging free in air with power applied to it (plugged into the AF meter). It needs to warm up for a couple minutes. It will get hot. If it's not hot, it's not powered up correctly.
Steve
X-Metal
Indiana
you might need to disconnect the 02 sensor so it can recalibrate itself. start over and reset everything. double check your 02 sensor is recieving power also
Steve 00RT/10
Michigan
Checking for power is good, but you could still have a bad sensor. The sensor should start getting warm to the touch in 10-15 seconds.
Also...you never want to leave an O2 sensor installed and not have power to it when the engine is running. It will likely be ruined.
Steve
M
martyb
IL
Thanks guys, figured it out. I have open headers right now, and I drove the car around the block, but the a/f stayed at 16. I think I will have to complete the exhaust before I can start getting any accurate readings.
Thanks for the input guys. My neighbors all hate me now more than before. Roe/Heads/Cam and open headers makes for a loud ride!
X-Metal
Indiana
wellllll yeah, you have to have at least 2ft of pipe after the 02 ****--minum
M
martyb
IL
Thanks xmetal, the rest of the exhaust should be done in a few weeks.
SKY1960
