Will a 2008 ACR rear Diff housing bolt into a 2006 Vert
Abe Froman
Rio Rancho, NM
I wanted to ask if a complete rear housing assembly from a 2008 ACR with a Quaife 3:55 will bolt into a 2006 Gen-III Vert?? A friend is selling his ACR and offered his Diff assembly to me for 2k. The diff has approximitly 1000 miles on the Quaife, axle assembly and housing. This sounds like a fair price, am I correct??
Hamrhead
eastern, Pa
FWIW, I just purchased a Brand New Stock '08 Diff w/ 3.55's (already installed) from Unitrax for 2K.
Shortly I'll be looking to sell my factory stock diff (3.07 gears - 500 miles). Thinking of asking around ~1K.
With the Quaife, it sounds like a fair deal to me.
redtanrt10
Dana Point CA
Differential Assembly - P5153993 MSRP $1600.00
2008 Viper differential assembly with Visco Loc limited slip differential [Direct replacement for 2003-06 and 2008 differential assemblies]. Complete differential assembly with all new components and MOPAR Performance gear set - fully assembly to production specifications.
Assembly includes:
>New aluminum housing with specialty cast-in bosses for MOPAR Performance differential cooler fittings [Bosses are drilled, tapped and pluged in three places, ready for cooler fitting installation]
>New improved design pinion seal.
>3:06-1 gear set.
Viper X
I'd call Devon at Unitrax. He will likely know.
I know there was a change during production in 2008 where Dodge upgraded the strength of the 1/2 shalfts. They may or may not have changed the spline numbers or shaft size - wish I could help more.
the 2008 diff may or may not work with a Gen III.
I'd like to know too, so please post when you find out.
Dan
3SXVPR
Charlotte NC
I installed a 2006 rear diff with a 3.55 Quaife into my '08 so I would assume it will go the other way around.
michaelnouri
Owensville Missouri 65066
yes it will fit any 03-09
all housing will slide in acr or non acr.
2k is a deal, although you lose your limited warranty
viso locs are not so hot compared to a quaife or superlock
put a viso behind turbo, will not last to long.
however, they are a big upgrade over the 03-06 hydrolock that srt contracted though dana, worst oem rearend ever produced and installed in a production car.
Brian R
