Will a jump start charge the battery from the underhood posts? (battery charger?) ---
alwayscode390
STL
I have gotten slammed at work and haven't had time to change out the power steering pulley that broke on me last week.
The temps here have dropped from 55 to 25 ... and I am pretty sure I am about to deal with a dying battery.
My belt is not on the car right now ... and I need to get it to the shop less than 5 miles up the street.
To make sure my battery lasts the 5 minutes I need it to ... do you think I should add jumper cables to the underhood battery posts of the Viper , then to a running car for a few minutes? That should add a charge to the Viper battery, right?
How safe is it to try to charge the battery from the underhood posts using an actual battery charger?
This is my first time with a "remote battery" ... and jacking the car up, taking off the wheel, and taking out the battery are my last option before getting the car towed. I don't trust tow trucks with these cars ... they sit too low.
I don't want to put the belt back on with the broken pulley either ... it will just get thrown back off , and I don't have the time to do the pulley/mount swap myself for atleast another 2 weeks.
Thanks for the help and advice :) ---
Omaha NE.
Re: Will a jump start charge the battery from the underhood posts? (battery charger?)
You can for sure charge the battery with a trickle charger from under the hood, I think if it is dead you would be running it a long time to charge enough that when you shut it off it would start again, just put the trickle on it overnight.
A
alwayscode390
STL
I was reading about the pcm issue with people using those Jump Start Boxes ... so should I stay clear of the "fast start"(12amp) setting and just keep the trickle on it (2amp)? ---
speedracervr4
Lancaster, PA
Put the trickle on it overnight and then hope it has enough juice to make it to the shop. Maybe worth just waiting two weeks and doing the pulley yourself.
A 2 amp overnight charge should do it. Hookup under the hood! Never use the boost mode, low amps is always better.
alwayscode390, I think that you'll find the main worry is not the portable, external battery packs (assuming that's what you mean by "Jump Start Boxes ")...but theextra "boost to start" or "engine start" setting found on many chargers. Some of the larger chargers deliver a 50-200 amp surge into the system...which has been noted to have a relationship with blown PCM's on Gen II Vipers ( and some Dakotas and Jeeps).
Viper98912
Atlanta
I put my battery tender through the hood gill
ontariomystic
Ontario
^^ Thats what I do.
A
alwayscode390
STL
Thanks everyone, I will try the Trickle charge first, and go from there. I appreciate the advice :) ---
Tom Sessions
Hampstead,NC.
I would be more worried about trying to drive the car 5 miles with no belt and having the engine overheat. These things do heat up in a hurry. Not sure if its worth the risk.
A
alwayscode390
STL
Do you think it would overheat in 5 miles with 25 degree weather? Honestly that is a concern of mine too. This situation is ******* me off honestly. Its such a small thing to go wrong and is turning into a pain in my ass LOL. I may just get it towed ... but I am really worried about getting the car scraped up going on/off the truck ---
if you have AAA, get them to pick it u and bring it to your mechanic or home, dont risk driving it. not worth the risk
Viper98912
Atlanta
Driving a car 5 miles down the road is a long way.
Call a special towing company that deals with lowered/specialty vehicles....
Viper Wizard
South Salem, NY USA
Tom & Plum are right, DO NOT DRIVE IT!! You WILL cook your motor in 5 miles! To flatbed her, tell the tow outfit to bring two 2"X10"X6' boards to break the angle at the bottom of the bed and tell them they will need two "R" hooks to be placed into the frame rail tie-down holes. DO NOT let them hook you lower control arms to pull her up onto the bed!! Charging from remote jump points 2amps ONLY!!
Questions....914-763-3136
Re-word to stop auto-links! :smirk:
there you have it.
A
alwayscode390
STL
OK guys, you talked me into a tow job ... waiting to do this myself ... or I just was recommended a "mobile car doctor" that will show up to the car and fix it on site.
This is a simple job so I don't think I need to worry about it being my main mechanic or not.
I really appreciate you guys talking me out of driving it , because I was going to try!!! ---
"or I just was recommended a "mobile car doctor" that will show up to the car and fix it on site.
This is a simple job so I don't think I need to worry about it being my main mechanic or not."
I HOPE you are kidding with the above statement !!
Viper98912
Atlanta
No problem, you can find lots of mobile mechanics on craigslist to work on your viper.
