Window Fell Off The Guides, How Do I Remove The Door Panel And Fix?
dave6666
Screw inside handle area.
2 screws behind door speaker.
Screw near hinge.
Screw near e-latch release.
Screw on bottom near catch.
One pop fastener near latch area mid door. Must pry loose last.
B
banal
Rockville, Maryland
Ok so I got the door panel off and now there's this big sealed plastic covering the entire door insides so I can't reach in. Any thoughts? Thanks!
B
banal
Rockville, Maryland
so it's at the dealership and they say the window regulator is broken. I said bs because when I had the door panel off it was working entirely fine. I went in and they showed me that the little white plastic clip that holds the glass to the wire had broken off and that the entire window regulator needs to be replaced...
02 Graphite GTS
H. B. California
I'm betting that with a little (okay, maybe a lot) of time searching on the internet, you'd be able to find a replacement clip for a whole lot less money than the entire window regulator.
potterb4
