Window prob
Rick530
NorCal -530-
When the pass window gets to the top it makes a growling noise I guess you would call it from inside the door. Up or down dosent matter but only does it when almost all teh way at the top. Thought it was just the rubber being dry but even when the door is opened it does it. Almost seems like the window is trying to go up to far or something. Have to take it in for an oil change soon so will need to get this checked out. Anyone have any ideas wth is going on?? Thanks.
2008 coupe.
Viper Wizard
South Salem, NY USA
Hey
I'm also going with the regulator. It has been a common problem - the housing for the push-pull cable cracks and lets the cable go to far in either direction. Can you say warranty!
rlamorte
