androbud
I thought I'd share what I recently learned in fixing my wiper motor problem.
I've had the problem where my passenger side wiper motor was acting up and colliding with the drivers side arm. I never tried to fix it because in Alabama cars don't have to go through safety inspections every year. Now that I moved to Tennessee I had to actually fix the problem.
By then the driver's side motor was completely dead. I confirmed this by hooking a lead from the positive battery terminal to the battery pin for the wiper motor and a ground lead to the low speed pin resulting in no movement. I decided to open up the motor housing and found that the windings were extremely corroded and green! Knowing this I decided to by a cheaper passenger side wiper motor and try to swap just the guts out of it.
I bought a passenger side motor off eBay for $75. When it arrived I confirmed the donor motor was good by doing the test described above. After I spliced the 3 wires leading from the capacitor on the wiper motor and switched the coil and coil housing to my old motor it worked great!
Now both wiper motors worked but I was still having the original problem with the arms colliding. I opened the housing and tried cleaning the motor position sensor but had no luck getting any different results. Now instead of removing the donor sensor and doing more splicing I just swapped everything back everything the way it originally was, coil housing and all. I then basically just took the donor passenger side motor and swapped mounting brackets with the old driver's side faulty motor.
It worked!!! I now have working windshield wipers again with no interference problems and I used 2 passenger side motors to do it! Any of you who have been putting off this fix because of the cost of a driver's side motor can now do it much cheaper!
