Andrew, for those cars without ABS, the OEM brake balance isn't too good. Yes, most of the braking happens up front, but the OEM rear brakes are so small that they don't do their share. Complaints of front wheel lock-up, poor control in sudden situations and overheating the fronts can be substantially reduced or eliminated if the rear brakes did a little more work.
The StopTech* front caliper setup addresses this by using smaller pistons in those calipers. The smaller size up front slightly reduces brake clamping force, but results in a better front-to-rear brake balance. Lots of folks are happy with this improvement, and by enlarging the rears to 38mm diameter, this same front-to-rear balance is achieved.
Going to 40mm provides even more rear brake clamping force, enough to just about make all four wheels each do their fair share (notice I didn't say equal) under heavy braking. It will feel more comfortable on the street and at Pocono, you get more pedal control, and you don't have to drive the car around the capabilities of the front brakes. Chuck installed a pair on Ghetto Viper's car recently and gave it a test drive. Ask him and Tom M. for their comments.
It's also a valuable help to have more rear brake if you tow with your Viper...
You don't need special pads, different brake lines, rotors, to cut off any brackets, to add a parking brake, etc. It uses 100% of the OEM system, so it is a direct swap. I'll send you something - check your email.
*StopTech doesn't endorse or even know about what I'm doing. I just use their system as a reliable point of reference.
