Viper will not start. help
dougwiggins
When I press the start button nothing happens except that the radio goes dead.
Does anyone know what is the problem.
Thanks.
Racer Robbie
Guilford, CT-USA
Disconnect your battery, charge it, and then do a load test on it. This will tell you if the battery is good or bad. My bet is that your battery is no good or you have a bad ground connection. Make sure to check the fuses and circuit breakers.
ctrengine
